Программа diskpart обнаружила ошибку ошибка в данных. Основы DISKPART. Основные команды DISKPART
In the eventuality that you have been using computers since the early 1990s, then there is a chance that you heard of fdisk. If not, this is a utility embedded in the MS-DOS and Windows that allows users to format hard disk and create logical partitions. Microsoft DiskPart is a tool that replaces this handy application in operating systems starting with Windows 2000.
Allows you to preview details of the drive before making any adjustments
The program does not feature an interface, but rather you can install and access it using Command Line. On a side note, on Windows 10, the utility does not work with PowerShell. Following the straightforward installation, you can access the tool and commence managing your disks and volumes.
It is worth mentioning that the tool uses scripts and hence, it is recommended that you list and select the object of choice before performing various operations. Once selected, you will be happy to learn that you can find out more about the volume you are managing via the detail command. At the same time, you can assign new letters to the partitions and set the primary drive.
The application works with standard, extended and logical partitions and you can remove or further extend the ones already configured. Other noteworthy operations include import, retain, create volume stripe or setting up a raid from multiple hard drives. Moreover, you can change a drive into a dynamic or basic one using the convert command and selecting the MBR or GPT partitioning styles.
A comprehensive tool for formatting and setting partitions on your HDD
In spite of the CLI operation, Microsoft DiskPart is a reliable tool that enables you to adequately prepare and partition a brand new or older hard drive. Not only does it allow you to grab explicit information about the disk volumes but advanced users can conveniently manage multiple disks, volumes and create as many partitions as necessary.
Легкая портативная программа для эффективного управления жесткими дисками Вашего компьютера. Поддерживает все современные модели HDD, стабильно работает с популярными файловыми системами, без проблем понимает оба способа хранения информации о разделах диска MBR и GPT.
Macrorit Disk Partition Expert Free Edition
Это удобная программная оболочка с продвинутыми инструментами управления свойствами дисков. Программа обладает простым и понятным графическим интерфейсом, который схож по функционалу с аналогичными утилитами.
По заявлению разработчиков данного ПО из компании Macrorit – “Даже бесплатная версия Disk Partition Expert превосходит по возможностям и стабильности именитые EASEUS Partition Master и Acronis Disk Director.
После запуска программы перед Вами отображается главное окно программы, зоны которого распределены на участки отображения информации о свойствах жестких дисков и блоков управления с инструментами.
Для тех пользователей, которые ранее работали в аналогичных программах, алгоритм действий будет сразу понятен.
Основные возможности Macrorit Disk Partition Expert:
- Создание загрузочных дисков
- Миграция разделов с операционной системой
- Изменение размеров разделов
- Перераспределение пространства на дисках
- Преобразование файловой системы
- Копирование разделов
- Смена активного раздела
- Управление буквой партиции
- Проверка поверхности дисков
- Выполнение дефрагментации
- Удаление области HDD
- Просмотр подробных свойств диска
Macrorit Disk Partition - это портативная программа для управления разделами жесткого диска. Благодаря этому инструменту вы сможете не только изменять размеры отдельных разделов без их предварительного форматирования, но и оптимизировать общую скорость работы HDD/SSD.
В главном окне Macrorit Disk Partition отображается основная информация об установленных в системе дисках: общий объем, объем свободного пространства, файловая система и текущее "здоровье". Также программа указывает разделы и загрузочные области, которые располагаются на каждом физическом носителе. Для того чтобы получить более подробные сведения о дисках, необходимо выбрать пункт "Свойства" в контекстном меню раздела. Там же (в контекстном меню) вы найдете и другие функции, которые умеет выполнять Macrorit Disk Partition: изменение размеров, копирование раздела, изменение метки, проверка тома на наличие ошибок, дефрагментация, удаление раздела, форматирование, полная очистка и анализ поверхности носителя. Еще в программе предусмотрен инструмент создания загрузочных накопителей.
Практически для каждой функции в Macrorit Disk Partition выделен специальный пошаговый мастер с подробными пояснениями и подсказками. Разработчики из Macrorit сделали все для того, чтобы работать с их программой было максимально комфортно. Это один из немногих менеджеров жесткого диска, который является совершенно бесплатным для домашнего использования. Существует также платная версия Professional, которая предлагает пользователям круглосуточную техническую поддержку и несколько дополнительных функций.
- возможность управления размерами существующих разделов без предварительного форматирования;
- возможность выделения новых разделов и назначения им нужных меток;
- наличие инструментов для дефрагментации, проверки поверхности диска, форматирования и полной очистки данных из раздела;
- возможность оценки текущего состояния физического носителя;
- функция создания загрузочных носителей;
- раздел с подробной информацией о секторах;
- возможность работы в портативном режиме (без установки в систему).
Для различных задач, которые встают перед пользователями, к примеру, нужно создать загрузочную флешку или появилась проблемы с форматированием флешки стандартными средствами из проводника, появляется необходимость форматирования флешки с помощью командной строки. Форматирование флешки через командную строку можно осуществить несколькими способами.
Для того, чтобы вызвать командную строку, запускаем меню Пуск и вписываем в строку поиска команду cmd.
В появившемся окне командной строки вписываем: format /fs:NTFS H: /q – где:
- format – задание на форматирование;
- fs:NTFS – описание выбираемой нами файловой системы;
- H: — нужный нам накопитель;
- /q — команда на быстрое форматирование.
В том случае, если мы захотим отформатировать файловую систему в Fat или в Fat32, команда будет выглядеть следующим образом: format /FS:FAT32 H: /q.
После ввода команды выведется сообщение: «Вставьте новый диск в дисковод H: и нажмите клавишу ENTER…» – нажмем ENTER.
Затем в окне командной строки выводится: «Метка тома (11 символов, ENTER — метка не нужна)» —
так жмем на ENTER.
Наша флешка отформатирована.
Команда Format (второй способ)
Вызываем командную строку как описано в пункте первом.
Набираем в появившемся окне командной строки: format H: /fs:NTFS /v:Arhiv – где:
- format – задача на форматирование диска;
- fs:NTFS – описание выбираемой нами файловой систем;
- v:Arhiv – метка выбираемого нами накопителя (вписывается наименование вашего диска).
Соответственно, при выборе нами другой файловой системы после fs: вписываем то, что нам необходимо – Fat или Fat32. Команда выглядит следующим образом: format H: /fs:FAT32 /v:Arhiv. В случае, если вы хотите выбрать быстрое форматирование, в команду на форматирование нужно дописать Q и команда будет выглядеть так: format H: /FS:NTFS /Q /v:arhiv.
Сразу после ввода команды в окне командной строки появляется оповещение: «Вставьте новый диск в дисковод H: и нажмите клавишу ENTER…» – нажимаем клавишу Ввод.
Флешка отформатирована.
Способ 3. Встроенная утилита Diskpart
В операционной системе Windows находится встроенная утилита для работы с накопителями, которая позволяет нам отформатировать флешку.
Вызываем командную строку командой cmd в поисковой строке меню Пуск.
В окне появившейся командной строки вводим: diskpart и запускается утилита для управления пространствами накопителей.
Набираем команду: list disk. Это позволит нам увидеть все накопители, присутствующие на нашем компьютере. Находим флешку, которую собираемся форматировать по объему. Нам стали видны все диски с указанием их объемов. Запоминаем номер выбираемого нами диска, например, 2.
Затем набираем команду: select disk 2, где 2 – выбираемый нами накопитель. Жмем Enter.
После этого, флешку необходимо очистить от атрибутов, для чего вводим команду: attributes disk clear readonly. После этого вводим команду: clean.
После очистки накопителя от атрибутов нам необходимо создать первичный раздел, для чего размечаем наш диск в выбранной нами файловой системе:
Сначала вводим команду: create partition primary, затем задаем необходимую нам файловую систему командой: format fs=ntfs или format fs=fat32. Если необходимо быстрое форматирование, то команду пишем следующим образом: format fs=NTFS QUICK или format fs=FAT32 QUICK. Нажимаем на Ввод и флешка форматируется.
Выход из программы осуществляем командой: exit.
Встроенная утилита Diskpart (еще один способ)
Существует еще один, немного отличающийся, способ форматирования накопителя с помощью встроенной программы Diskpart.
Вызываем окно командной строки, как рассказано выше, затем вводим команду diskpart и нажимаем Ввод для запуска утилиты.
Затем вводим команду list disk и снова жмем Ввод. Так мы увидим все свои накопители. После этого, так же, как и в предыдущем способе, распознаем свою флешку по размеру и запоминаем номер накопителя. Например, 2.
Пишем команду: select disk 2, где 2 – выбираемая нами флешка. Нажимаем на Enter.
Вписываем команду clean и нажимаем Enter – удаляются все файлы на накопителе.
Далее необходимо создать новый раздел на флешке, для чего вводится команда: create partition primary и Ввод, затем команда выбора диска: select disk 2 и Ввод, где 2 – нужный нам накопитель. После чего нужно ввести команду: active, чтобы утилита пометила раздел как активный. Затем вводим команду для разметки файловой системы: format fs=ntfs или format fs=fat32. Как говорилось в предыдущем способе, для быстрого форматирования добавляем в команду QUICK: format fs=NTFS QUICK или format fs=FAT32 QUICK.
После окончания форматирования нужно присвоить флешке букву. Делаем это с помощью команды: assign, после чего происходит автозапуск накопителя, и мы видим на экране окно проводника с уже отформатированной флешкой.
Для завершения работы в Diskpart пользуемся командой exit.
Как мы показали в данной статье, сделать форматирование флешки через командную строку несложно. Главное, внимательно выбирать диск для форматирования и помнить, что после форматирования ваши данные могут быть утрачены навсегда. Работа в командной строке поможет особенно в случае работы со встроенной утилитой Diskpart, если флешку не удается отформатировать простым способом из меню проводника или при работе с флешкой вы заметили, что часть файловой системы не видна и объем флешки по какой-то причине уменьшился.
Нередко случается, что многие современные компьютеры не имеют дисковода. Это нередко вызывает затруднения, в особенности, когда необходимо установить программу с установочного диска. Чаще всего проблема возникает при установке или переустановке операционной системы Windows на такой компьютер. Чтобы избежать таких проблем предлагается создать загрузочный usb-накопитель , который будет выполнять все функции в точности, как и установочный диск.
Для создания загрузочного usb-накопителя или иногда его ещё называют загрузочной флешкой с помощью командной строки «cmd», необходимо выполнить простой алгоритм действий в два этапа. В первом этапе будет задействовано использование стандартной утилиты под названием diskpart .
Как работает diskpart
Создание загрузочного флеш-накопителя через консольную утилиту diskpart является быстрым и доступным способ. Благодаря тому, что данная утилита работает в текстовом режиме, каждый пользователь персонального компьютера с легкостью справится с такой задачей.
С быстрым развитием технологий, каждому человеку доступен выход в Интернет, где можно найти бесплатные версии различных программ по созданию загрузочного флеш-накопителя. Однако случается и такое, что доступ к Интернету отсутствует в силу каких-либо обстоятельств, поэтому важно знать несколько простых альтернативных способов создания загрузочного флеш-накопителя.
Один из них - описанный метод, применяющий командную строку. Такой ручной способ пригодится каждому пользователю ПК. Эта консольная утилита входит в перечень стандартных программ . Нет необходимости дополнительно искать и устанавливать какие-либо другие программы по настройке загрузочного флеш-накопителя. Через десять минут использования diskpart готова загрузочная флешка с установочным файлом Windows.
Готовим флешку с помощью diskpart
Diskpart – это консольная системная программа, входящая в состав Windows, через которую можно осуществлять управление дисками, разделами и томами путем прямого ввода команд.
Создание загрузочного флеш-накопителя с помощью командной строки будет показано наглядно. В качестве примера будет использована операционная система Windows 8. На других версиях операционной системы Windows, таких как Windows 7 либо Windows 10 процесс создания будет идентичен.
Перед началом работы необходимо подключить переносной диск или флеш-накопитель , либо другой съемный носитель к компьютеру. Такое устройство далее будет обозначаться как флеш-накопитель.
Затем нажать сочетание клавиш Win + X или щелкните правой кнопкой мыши в левом нижнем углу экрана. Для тех, кто еще знает что это за кнопка Win напоминаем:
Выберите пункт меню «Командная строка (администратор) ».
Если вам удобнее вызвать окно «Выполнить » с помощью Win + R , то можете сделать так, введя в открывшемся окне «cmd » и нажав OK . Эти действия приведут к аналогичному результату.
В открывшемся окне введите diskpart и нажмите клавишу ввода Enter .
Конечно, более вероятно, что необходимость создания флешки возникнет не из операционной системы, где есть более простые и удобные способы, а из чистой командной строки во время перезапуска ПК.
После этого необходимо ввести данные так же, как показано на картинке ниже. После каждой введенной команды нажимать клавишу ввода Enter .
- list disk – будет отображен список имеющихся дисков;
- select disk # – вместо # ввести номер диска, который является флеш-накопителем, он и будет загрузочным (на примере это диск под номером 1); отличить флешку от других дисков легко по её размеру;
- clean – диск будет очищен, вся предыдущая информация будет удалена
- create partition primary – создается специальный раздел
- active – раздел активируется
- format fs=ntfs quick – будет произведено форматирование диска
- assign – будет присвоено имя диска и назначена точка подключения
- exit – операция завершена. Осуществится выход из командной строки.
Первый этап создания загрузочного флеш-накопителя завершен.
Копирование файлов на флешку
Следующим этапом станет копирование установочных файлов программы на флеш-накопитель. Копировать нужно все файлы полностью со всей структурой и каталогами.
Сделать это можно с применением стандартных инструментов Windows типа «Проводник». Если вы хотите в силу разных возможных причин сделать это с помощью той же самой командной строки, то в этом вам помогут следующие команды:
- Улучшенная команда копирования «robocopy », в отличие от устаревшей «copy» может копировать вложенные папки со всем содержимым. В качестве первого аргумента команды выступает путь к копируемым файлам, а второго - путь к папке, в которую будет выполнено копирование файлов. Для копирования вложенных папок необходимо добавить третий аргумент «/E », иначе будет скопированы только файлы. Например, чтобы скопировать все файлы с диска f на флешку с именем g: вам требуется ввести команду: robocopy f:\ g:\ /E
- Устаревшая команда копирования файлов «copy », воспользовавшись которой можно скопировать только файлы (папки придется создавать вручную командой «md»). В качестве первого аргумента команды выступает путь к копируемым файлам, а второго - путь к папке, в которую будет выполнено копирование файлов. Чтобы дать понять команде, что вы хотите скопировать не один файл в папке, а все файлы, в качестве имени файла укажите код «*.*».
- Команда смены диска, формат которой такой: ДИСК:
. Т.е. для перехода на диск «D:\» необходимо ввести такую команду: d: - Чтобы выбрать директорию, расположенную в текущей папке введите cd <имя директории>, например: cd win10
- Для перехода на верхний уровень файловой иерархии введите cd \
- Для перехода к родительской папке напишите cd ..
- Чтобы посмотреть перечень файлов текущей папки, введите команду dir
- Для создания папки запустите команду md <имя папки>
Знания указанных команд достаточно для успешного копирования файлов на флешку.
Вот как это будет выглядеть для случая копирования установочных файлов, расположенных на диске d:\win10 и флешки с именем «G:\». Подготовка и запуск robocopy :
Через определенное время все файлы будут успешно скопированы:
Чаще всего загрузочный флеш-накопитель используют для установки либо переустановки операционной системы. При отсутствии дисковода можно воспользоваться виртуальным DVD-приводом и файлом-образом.
При установке операционной системы с загрузочного флеш-накопителя, в BIOS необходимо изменить настройки так, чтобы компьютер загружался именно через это устройство.
Видео по теме
