Samsung Galaxy C5 - Технические характеристики. Samsung Galaxy C5 - Технические характеристики Мобильная сеть - это радио-система, которая позволяет множеству мобильных устройств обмениваться данными между собой
Each of the following remarks is only applicable to the corresponding product features or specifications which are related to such remark on this page.
◇The function is only available in 3G+Wi-Fi version.
^Subject to local network, data and messaging services.
*The talk time and stand-by time are approximate. Performance of the battery is subject to the network, signal strength, function, selection and profile.
**This function is only subject to call forwarding service subscription. Network providers may charge additional service fee.
△GPS/AGPS connection is subject to local network and data services and network providers may charge additional service fees. Additionally, connection times can be affected by external factors, such as surrounding environment, weather, etc
▲User memory is less than the total memory due to storage of the operating system and software used to operate the device features. Actual user memory will vary depending on the operator and may change after software upgrades are performed.
#Stereo Bluetooth is only applicable to specific headsets.
For reference only, please check with our staff for details.
◆For details of the latest OS version, please visit the firmware upgrade page.
ˇActual feature may differ depending on the OS version.
⊿GPS connection time can be affected by external factors, such as surrounding environment, weather, etc.
***Performance of the battery is subject to the network,signal strength,function,selection and profile. Battery time is based on our own laboratory measurements, and may vary depending on factors such as device settings, usage patterns and operating conditions.
^^3G Network in HK: WCDMA; 3G Network in Mainland China: TD-SCDMA and WCDMA (Galaxy Note8, Galaxy S8, Galaxy S8+ even supports TD-SCDMA); 4G Network in HK and China: FDD-LTE and TDD-LTE. Subject to local network, data and messaging services. Galaxy A8+ does not support China Telecom (China), China Telecom (Macau) Network, China Mobile (China) 4G TDD-LTE (B39) network and 3G network TD-SCDMA.
Network band: The bandwidths supported by the device may vary depending on the region or service provider.
◇◇The network capacity and data transfer speed may be reduced while dual SIM cards are used at the same time, applicable to Galaxy S6 (SM-G9200ZWUTGY) only.
Features and specifications are subject to change without prior notification.
When one of the SIM slots supports 4G or 3G networks, the other SIM slot supports only the 2G networks.
When one of the SIM cards supports 4G or 3G networks, the other SIM card supports only the 3G or 2G networks, vice versa. (Only applicable to Galaxy J7 Prime, Galaxy C7, Galaxy C5, Galaxy J5 Prime, Galaxy S7 edge)
MicroSD card and SIM card cannot be placed in MicroSD card tray at the same time. Only either of them fit into the tray. (Only applicable to Galaxy A8 Star)
Google+, Google, the Google logo, Google Search, Google Maps, Gmail, YouTube, Android, Google Play and Messenger is the trademark of Google Inc. All other products and services mentioned may belong to their respective trademark owners.
Images are for reference only.
MicroSD is sold separately.
All specifications and descriptions provided herein may be different from the actual specifications and descriptions for the product. The contents within the screen are simulated images and are for demonstration purposes only. All functionality, features, specifications, GUI and other product information provided in this document including, but not limited to, the benefits, design, pricing, components, performance, availability, and capabilities of the product are subject to change without notice or obligation.
Дизайн
Ширина Информация о ширине - имеется ввиду горизонтальная сторона устройства при его стандартной ориентации во время употребления. | 72 мм (миллиметры)
7.2 см (сантиметры) 0.24 ft (футы) 2.83 in (дюймы) |
Высота Информация о высоте - имеется ввиду вертикальная сторона устройства при его стандартной ориентации во время употребления. | 145.9 мм (миллиметры)
14.59 см (сантиметры) 0.48 ft (футы) 5.74 in (дюймы) |
Толщина Информация о толщине устройства в разных единицах измерения. | 6.7 мм (миллиметры)
0.67 см (сантиметры) 0.02 ft (футы) 0.26 in (дюймы) |
Вес Информация о весе устройства в разных единицах измерения. | 143 г (граммы)
0.32 lbs (фунты) 5.04 oz (унции) |
Объем Приблизительный объем устройства, вычисленный на основе размеров, предоставленных производителем. Относится к устройствам с формой прямоугольного параллелепипеда. | 70.38 см³ (кубические сантиметры)
4.27 in³ (кубические дюймы) |
Цвета Информация о цветах, в которых предлагается в продаже данное устройство. | Розовое золото Золотистый Серебристый Серый |
Материалы для изготовления корпуса Материалы, использованные для изготовления корпуса устройства. | Металл |
SIM-карта
Мобильные сети
GSM GSM (Global System for Mobile Communications) разработана, чтобы заменить аналоговую мобильную сеть (1G). По этой причине GSM очень часто называется и 2G мобильной сетью. Она улучшена добавлением GPRS (General Packet Radio Services), а позднее и EDGE (Enhanced Data rates for GSM Evolution) технологий. | GSM 850 MHz GSM 900 MHz GSM 1800 MHz GSM 1900 MHz |
CDMA CDMA (Code-Division Multiple Access) - это канальный метод доступа, использованный при коммуникациях в мобильных сетях. По сравнению с другими 2G и 2.5G стандартами, как GSM и TDMA, он предоставляет более высокие скорости переноса данных и возможность соединения большего количества потребителей в одно и то же время. | CDMA 800 MHz |
TD-SCDMA TD-SCDMA (Time Division Synchronous Code Division Multiple Access) - это 3G стандарт мобильных сетей. Его называют еще и UTRA/UMTS-TDD LCR. Он разработан как альтернатива W-CDMA стандарта в Китае Китайской академией телекоммуникационных технологий, компаниями Датанг Телеком и Сименс. TD-SCDMA сочетает в себе TDMA и CDMA. | TD-SCDMA 1880-1920 MHz TD-SCDMA 2010-2025 MHz |
UMTS UMTS - это сокращение Universal Mobile Telecommunications System. Она базирована на GSM стандарт и относится к 3G мобильным сетям. Разработана 3GPP и ее самым большим преимуществом является предоставление большей скорости и спектральной эффективности благодаря W-CDMA технологии. | UMTS 850 MHz UMTS 900 MHz UMTS 1900 MHz UMTS 2100 MHz |
LTE LTE (Long Term Evolution) определяется как технология четвертого поколения (4G). Она разработана 3GPP на базе GSM/EDGE и UMTS/HSPA с целью увеличить емкость и скорость беспроводных мобильных сетей. Последующее развитие технологий называется LTE Advanced. | LTE 900 MHz LTE 1800 MHz LTE 2100 MHz LTE 2600 MHz LTE-TDD 1900 MHz (B39) LTE-TDD 2300 MHz (B40) LTE-TDD 2500 MHz (B41) LTE-TDD 2600 MHz (B38) |
Oперационная система
SoC (Система на кристалле)
SoC (Система на кристалле) Система на кристалле (SoC) интегрирует различные хардверные компоненты, таких как процессор, графический процессор, память, периферия, интерфейсы и др., а также и софтвер, необходимый для их функционирования. | Qualcomm Snapdragon 617 MSM8952 |
Технологический процесс Информация о технологическом процессе, по которому изготовлен чип. Величиной в нанометрах измеряют половину расстояния между элементами в процессоре. | 28 нм (нанометры) |
Процессор (CPU) Основная функция процессора (CPU) мобильного устройства - это интерпретация и выполнение инструкций, содержащихся в программных приложениях. | 4x 1.5 GHz ARM Cortex-A53, 4x 1.2 GHz ARM Cortex-A53 |
Разрядность процессора Разрядность (биты) процессора определяется размером (в битах) регистров, адресных шин и шин для данных. 64-битные процессоры обладают более высокой производительностью по сравнению с 32-битными, которые со своей стороны более производительны, чем 16-битные процессоры. | 64 бит |
Архитектура набора команд Инструкции - это команды, с помощью которых софтуер задает/управляет работой процессора. Информация об наборе командов (ISA), которые процессор может выполнять. | ARMv8 |
Кэш-память нулевого уровня (L0) Некоторые процессоры располагают L0 (уровень 0) кеш-памятью, доступ к которой быстрее, чем к L1, L2, L3 и т.д. Преимущество наличия такой памяти - не только более высокая производительность, но и снижение потребления электроэнергии. | 4 кБ + 4 кБ (килобайты) |
Кэш-память первого уровня (L1) Кэш-память используется процессором, чтобы сократить время доступа к более часто используемым данным и инструкциям. L1 (уровень 1) кэш-память отличается маленьким объемом и работает намного быстрее как системной памяти, так и остальных уровней кэш-памяти. Если процессор не обнаружит запрашиваемых данных в L1, он продолжает искать их в L2 кэш-памяти. При некоторых процессорах этот поиск производится одновременно в L1 и L2. | 16 кБ + 16 кБ (килобайты) |
Кэш-память второго уровня (L2) L2 (уровень 2) кэш-память медленнее L1, но взамен она отличается большим капацитетом, позволяющим кэширование большего количества данных. Она, так же как и L1, намного быстрее системной памяти (RAM). Если процессор не обнаружит запрашиваемых данных в L2, он продолжает искать их в L3 кэш-памяти (если таковая имеется в наличии) или в RAM-памяти. | 2048 кБ (килобайты)
2 МБ (мегабайты) |
Kоличество ядер процессора Ядро процессора выполняет программные инструкции. Существуют процессоры с одним, двумя и более ядрами. Наличие большего количества ядер увеличивает производительность, позволяя параллельное выполнение множества инструкций. | 8 |
Тактовая частота процессора Тактовая частота процессора описывает его скорость посредством циклов в секунду. Она измеряется в мегагерцах (MHz) или гигагерцах (GHz). | 1500 МГц (мегагерцы) |
Графический процессор (GPU) Графический процессор (GPU) обрабатывает вычисления для различных 2D/3D графических приложений. В мобильных устройствах он используется чаще всего играми, потребительским интерфейсом, видео-приложениями и др. | Qualcomm Adreno 405 |
Объём оперативной памяти (RAM) Оперативная память (RAM) используется операционной системой и всеми инсталлированными приложениями. Данные, которые сохраняются в оперативной памяти, теряются после выключения или рестартирования устройства. | 4 ГБ (гигабайты) |
Тип оперативной памяти (RAM) Информация о типе оперативной памяти (RAM) используемый устройством. | LPDDR3 |
Количество каналов оперативной памяти Информация о количестве каналов оперативной памяти каторые интегрированы в SoC. Больше каналов означает более высокие скорости передачи данных. | Одноканальная |
Частота оперативной памяти Частота оперативной памяти определяет ее скорость работы, более конкретно, скорость чтения/записи данных. | 933 МГц (мегагерцы) |
Встроенная память
Карты памяти
Карты памяти используются в мобильных устройствах для увеличения объема памяти для сохранения данных.
Экран
Тип/технология Одна из основных характеристик экрана - это технология, по которой он изготовлен и от которой напрямую зависит качество изображения информации. | Super AMOLED |
Диагональ У мобильных устройств размер экрана выражается посредством длины его диагонали, измеренной в дюймах. | 5.2 in (дюймы)
132.08 мм (миллиметры) 13.21 см (сантиметры) |
Ширина Приблизительная ширина экрана | 2.55 in (дюймы)
64.75 мм (миллиметры) 6.48 см (сантиметры) |
Высота Приблизительная высота экрана | 4.53 in (дюймы)
115.12 мм (миллиметры) 11.51 см (сантиметры) |
Соотношение сторон Соотношение размеров длинной стороны экрана к его короткой стороне | 1.778:1 16:9 |
Разрешение Разрешение экрана показывает количество пикселей по вертикали и горизонтали экрана. Более высокое разрешение означает более четкую деталь изображения. | 1080 x 1920 пикселей |
Плотность пикселей Информация о количестве пикселей на сантиметр или дюйм экрана. Более высокая плотность позволяет показывать информацию на экране с более четкими деталями. | 424 ppi (пикселей на дюйм)
166 ppcm (пикселей на сантиметр) |
Глубина цвета Глубина цвета экрана отражает общее количество битов, использованных для цветовых компонентов в одном пикселе. Информация о максимальном количестве цветов, которые экран может показать. | 24 бит 16777216 цветы |
Площадь, занимаемая экраном Приблизительная площадь в процентах, занимаемая экраном на передней панели устройства. | 71.19 % (проценты) |
Другие характеристики Информация о других функциях и характеристиках экрана. | Ёмкостный Мультитач |
Датчики
Основная камера
Основная камера мобильного устройства обычно расположена на задней части корпуса и используется для фото- и видеосъемки.
Модель датчика Информация о производителе и модели фотодатчика, использованного в камере устройства. | Samsung S5K3P3 |
Тип датчика Цифровые камеры используют фотодатчики для фотосъемки. Датчик, также как и оптика являются одним из основных факторов качества камеры в мобильном устройстве. | CMOS BSI (backside illumination) |
Размер датчика Информация о размерах фотодатчика, используемого в устройстве. Обычно камеры с более крупным датчиком и с меньшей плотностью пикселей предлагают более высокое качество изображения несмотря на более низкое разрешение. | 4.74 x 3.56 мм (миллиметры)
0.23 in (дюймы) |
Размер пикселя Меньший размер пикселя фотодатчика позволяет использовать больше пикселей на единицу площади, увеличивая таким образом разрешительную способность. С другой стороны, меньший размер пикселя может оказать отрицательное влияние на качество изображения при высоких уровнях светочувствительности (ISO). | 1.029 мкм (mикрометры)
0.001029 мм (миллиметры) |
Кроп-фактор Кроп-фактор - это соотношение между размерами полнокадрового датчика (36 х 24 мм, эквивалентный кадру стандартной 35 мм пленки) и размерами фотодатчика устройства. Указанное число представляет собой соотношение диагоналей полнокадрового датчика (43.3 мм) и фотодатчика конкретного устройства. | 7.29 |
Диафрагма | f/1.9 |
Фокусное расстояние | 3.7 мм (миллиметры)
26.99 мм (миллиметры) *(35 mm / full frame) |
Тип вспышки Наиболее часто встречающиеся типы вспышек в камерах мобильных устройств - это LED и ксеноновые вспышки. LED-вспышки дают более мягкий свет и в отличие от более ярких ксеноновых используются и при видеосъемках. | Двойная LED |
Разрешение изображения Одна из основных характеристик камер мобильных устройств - это их разрешение, которое показывает количество пикселей по горизонтали и вертикали изображения. | 4608 x 3456 пикселей 15.93 Мп (мегапикселей) |
Разрешающая способность видео Информация о максимально поддерживаемом разрешении при видеосъемке устройством. | 1920 x 1080 пикселей 2.07 Мп (мегапикселей) |
Видео - кадровая частота/кадров в сек. Информация о максимальном количестве кадров в секунду (fps), поддерживаемом устройством при видеосъемке с максимальным разрешением. Некоторые из основных стандартных скоростей съемки и воспроизведения видео - это 24p, 25p, 30p, 60p. | 30 кадров/сек (кадры в секунду) |
Характеристики Информация о других софтверных и хардверных характеристиках, связанных с основной камерой и улучшающих ее функциональность. | Автофокус Серийная съёмка Цифровой зум Географические метки Панорамная съёмка HDR съёмка Сенсорная фокусировка Распознавание лиц Настройка баланса белого Настройка ISO Компенсация экспозиции Автоспуск Режим выбора сцены |
Дополнительная камера
Дополнительные камеры обычно монтируются над экраном устройства и используются в основном для видеоразговоров, распознавания жестов и др.
Диафрагма Диафрагма (f-число) - это размер отверстия диафрагмы, который контролирует количество света, достигающего до фотодатчика. Более низкое f-число означает, что отверстие диафрагмы больше. | f/1.9 |
Фокусное расстояние Фокусное расстояние - это расстояние в миллиметрах от фотодатчика до оптического центра линзы. Указано также и эквивалентное фокусное расстояние, обеспечивающее то же самое поле видения при полнокадровой (full frame) камере. | 2.53 мм (миллиметры) |
Разрешение изображения Информация о максимальной разрешительной способности дополнительной камеры при съемке. В большинстве случаев разрешение дополнительной камеры ниже того, которое имеет основная камера. | 3264 x 2448 пикселей 7.99 Мп (мегапикселей) |
Аудио
Радио
Определение местоположения
Wi-Fi
Bluetooth
Версия Существует несколько версий Bluetooth, при этом каждая последующая улучшает скорость связи, охват, способствует более легкому обнаружению и подключению устройств. Информация о Bluetooth-версии устройства. | 4.2 |
Характеристики Bluetooth использует разные профили и протоколы, обеспечивающие более быстрый обмен данных, экономию энергии, улучшение обнаружения устройств и др. Некоторые из этих профилей и протоколов, которые поддерживает устройство, показаны здесь. | A2DP (Advanced Audio Distribution Profile) AVRCP (Audio/Visual Remote Control Profile) DIP (Device ID Profile) HFP (Hands-Free Profile) HID (Human Interface Profile) HSP (Headset Profile) MAP (Message Access Profile) OPP (Object Push Profile) PAN (Personal Area Networking Profile) PBAP/PAB (Phone Book Access Profile) HOGP |
USB
Разъём для наушников
Подключение устройств
Браузер
Браузер Информация о некоторых основных характеристиках и стандартах, поддерживаемых браузером устройства. | HTML HTML5 CSS 3 |
Форматы/кодеки звуковых файлов
Мобильные устройства поддерживают разные форматы и кодеки звуковых файлов, которые соответственно сохраняют и кодируют/декодируют цифровые аудиоданные.
Форматы/кодеки видео файлов
Аккумулятор
Ёмкость Емкость аккумулятора показывает максимальный заряд, который он способен сохранить, измеренный в миллиампер-часах. | 2600 мА·ч (миллиампер-часы) |
Тип Тип аккумулятора определяется его структурой и, точнее, используемыми химикалами. Существуют разные типы аккумуляторов, при этом чаще всего в мобильных устройствах используются литий-ионные и литий-ион-полимерные аккумуляторы. | Li-Ion (Литий-ионный) |
Время ожидания 2G Время ожидания в 2G - это период времени, за которое заряд аккумулятора разряжается полностью, когда устройство находится в режиме ожидания (stand-by) и подключено к 2G сети. | 237 ч (часы)
14220 мин (минуты) 9.9 дней |
Время ожидания 3G Время ожидания в 3G - это период времени, за которое заряд аккумулятора разряжается полностью, когда устройство находится в режиме ожидания (stand-by) и подключено к 3G сети. | 237 ч (часы)
Время ожидания 4G Время ожидания в 4G - это период времени, за которое заряд аккумулятора разряжается полностью, когда устройство находится в режиме ожидания (stand-by) и подключено к 4G сети. | 237 ч (часы)
Характеристики Информация о некоторых дополнительных характеристиках аккумулятора устройства. | Несъемный |
Удельный коэффициент поглощения (SAR)
Уровень SAR обозначают количество электромагнитной радиации, поглощаемой организмом человека во время пользования мобильным устройством.
Уровень SAR для головы (США) Уровень SAR указывает на максимальное количество электромагнитной радиации, которой подвергается организм человека, если держать мобильное устройство рядом с ухом. Максимальное значение, применяемое в США, составляет 1.6 Вт/кг на 1 грамм человеческой ткани. Мобильные устройства в США контролируются CTIA, а FCC проводит тесты и устанавливает их значения SAR. | 0.51 Вт/кг (Ватт на килограмм) |
Уровень SAR для тела (США) Уровень SAR указывает на максимальное количество электромагнитной радиации, которой подвергается организм человека, если держать мобильное устройство на уровне бедер. Самое высокое допустимое значение SAR в США составляет 1.6 Вт/кг на 1 грамм человеческой ткани. Это значение устанавливается FCC, а CTIA контролирует соответствие мобильных устройств данному стандарту. | 0.45 Вт/кг (Ватт на килограмм) |
TFT (Thin Film Transistor) - Жидко-кристаллические дисплеи, основанные на тонкопленочных транзисторах с активной матрицей. На каждый пиксель здесь приходится три транзистора, соответствующих трем цветам (RGB - красный, зеленый, синий). На данный момент, это самые распространенные дисплеи, имеющие ряд преимуществ над другими дисплеями. Они отличаются минимальным временем отклика и стремительным развитием - постоянно растущим разрешением и количеством цветов. Наиболее распространены данные дисплеи в телефонах среднего класса и выше. Рабочие разрешения для них: 128x160, 132x176, 176x208, 176x220, 240x320 и другие, менее распространенные. Примеры: Nokia N73 (240x320, 262тыс. цветов), Sony Ericsson K750i (176x220, 262тыс. цветов), Samsung D900 (240x320, 262тыс. цветов). TFT очень редко используются как внешние дисплеи для раскладушек.
CSTN (Color Super Twisted Nematic) - Цветные жидко-кристаллические дисплеи с пассивной матрицей. Каждый пиксель такого дисплея состоит из трех объединенных пикселей, которым соответствуют три цвета (RGB). Некоторое время назад практически все телефоны с цветными дисплеями были основаны, именно, на таком типе. А теперь удел таких дисплеев - бюджетные модели. Основной минус таких дисплеев - это их медлительность. Несомненным плюсом таких дисплеев является их себестоимость, она значительно ниже TFT. Исходя из простой логики, можно предположить, что в будущем TFT вытеснит с рынка мобильных аппаратов такой тип дисплеев. Эволюция цветности таких дисплеев достаточно обширная: от 16 до 65536 цветов. Примеры: Motorola V177 (128x160, 65тыс. цветов), Sony Ericsson J100i (96x64, 65тыс. цветов), Nokia 2310 (96x68, 65тыс. цветов).
UFB (Ultra Fine and Bright) - Жидко-кристаллические дисплеи с повышенной яркостью и контрастностью на пассивной матрице. Можно сказать, что это промежуточный вариант между CSTN и TFT. Такой тип дисплеев может похвастаться более низким энергопотреблением по сравнению с TFT. По большей части такие дисплеи применяла компания Samsung в телефонах среднего класса. Данный тип дисплеев не получил широкого распространения. Примеры: Samsung C100/110 (128x128, 65тыс. цветов).
TN - это один из типов матрицы TFT-экранов. Если грубо, то TN - это самые простые и дешевые матрицы TFT. Углы обзора самые узкие.
Super Active Matrix Organic Light-Emitting Diode (Super AMOLED) - улучшенная технология создания тачскринов на основе AMOLED. В отличие от предшественников, сенсорный слой приклеен к самому экрану, что позволяет избавиться от прослойки воздуха в промежутке между ними.
