Скачать блок лаунчер без вирусов. BlockLauncher Pro для Android (обновленно последняя версия). Что нового в BlockLauncher PRO
BlockLauncher Pro is a program with which you can install on the game client Minecraft Pocket Edition: mods , textures , Addons , patches and more ...
Each addition that you install on using BlockLauncher carries with it a certain burden on the program and the game itself, Minecraft Pocket Edition, and therefore can crash from BlockLauncher Minecraft Pocket Edition. Therefore, before installing multiple addons on Minecraft Pocket Edition, make sure that none of the addition does not create conflicts at work. For example, when you play with mod Factorization and install the addon Tessellation (3D Block) - can be a conflict between these supplements, so be careful when you install several addons for the game client Minecraft Pocket Edition using BlockLauncher.
Also many are interested in how to install Minecraft Pocket Edition Shaders - everything is very simple! Shaders are installed and maintained by the program BlockLauncher Pro and BlockLauncher Free as well as textures for Minecraft PE (Setting out identical!).
If you don"t know how to install the mod, texture, addon, Shader, program, simply go to any publication interested in the mod, texture or any other addition for Minecraft PE on our website, and at the end of the description addons, you will find instructions for the installation of selected addons for Minecraft Pocket Edition.
Features Of BlockLauncher:
- Installing texture packs (you Can use 2 textures pack at the same time (for example the Shader pack + textures pack)
- Setting Shader
- Installation of skins
- The installation of the patches
- Installation of Addons BL
- Install ModPE Script (Mods)
- Changing DPI
- And more ...
BlockLauncher contains:
This application has been compiled from a variety of public developments for importing and exporting files between storage and other applications - based on Android OS.
- aFileChooser by Paul Burke
- PTPatch Tool from Showbound, licensed under the Eclipse Public License
- Modification of texturata Slickcraft from NathanX with his permission
- Parts of texturata RepetiCraft отTheevipplz and and used with permission
- Cybia Substrate from Saurik framework, licensed under the GNU LGPL
- Chainfire libsuperuser
- The Rhino javascript engine from the Mozilla project.
Mods & Addons
Use our mods, the core engine of which is based on this launcher:Latest version : BlockLauncher - это для Minecraft PE на платформе Андроид , которая позволяет всем любителям управлять контентом для игры. С помощью данного приложения Вы сможете легко и удобно устанавливать , и для Майнкрафт ПЕ . Именно на нашем сайте Вы сможете с легкостью скачать данное приложение бесплатно.Особенности BlockLauncher
С помощью данного для Андроид Вы сможете добавлять любые улучшения для и иметь над ними контроль.- Моды. Для установки Вы должны скачать необходимый Вам файл. Если файл заархивирован, извлеките файл из архива. После данного действия войдите в BlockLauncher и нажмите на ключ серого цвета в верхней части интерфейса. Далее Вам нужно выбрать управление скриптами и нажать кнопку "Добавить". После данного действия у Вас появится несколько вариантов поиска скрипта. Подберите нужный Вам вариант, после чего войдите в и активируйте мод в игре.
- Текстуры. Скачайте необходимый файл и распакуйте его при необходимости. После чего войдите в приложение и повторите действия выше. Далее Вам нужно будет нажать кнопку "использовать текстурпак". Далее найдите и выберите , которые ранее Вы скачали и извлекли в память телефона.
- Патчи. Алгоритм установки тот же самый, что для и . Загрузите нужный Вам патч, зайдите в приложение BlockLauncher и нажмите на ключик. После чего выберите управление патчами и добавьте нужный Вам патч. Активируйте патч. Все готово!
- Аддоны. Аддоны для скачиваются как приложение и требуют отдельной установки. После скачивания войдите в лаунчер и активируйте нужный Вам .
Все описанные выше функции - это основные функции BlockLauncher . Также приложение имеет функцию снимка экрана. Чтобы сделать снимок экрана, нажмите на все тот же "ключ" в верхней части интерфейса и нажмите кнопку «скриншот» .
Данная программа незаменима для всех поклонников
BlockLauncher - наилучший лаунчер для , при помощи которого вы сможете устанавливать разнообразные дополнения к себе в игру. С Блоклаунчером вы сможете установить , патчи, и конечно же .
Вследствие того что, моды сделанные с помощью МодПЕ, который использует намного упрощенный JavaScript - язык программирования, многие из скриптов будут не сильно нагружать Ваше Андроид устройство.
К тому же при помощи Блоклаунчера вы сможете ставить шейдеры. Шейдеры устанавливаются точно также как и текстуры, по такой же инструкции, что несомненно облегчит вам процесс.
Особенности
- Возможность установки аддонов, патчей, текстур-пакетов и модов
- Возможность захвата видео с экрана Андроид
- Возможность изменения DPI
- Возможность включения режима безопасности (отключит все модификации)
- Полноэкранный режим
Немного ниже вы можете ознакомиться с различными инструкциями по установке дополнений к MCPE.
Установка аддонов
- Установите BL
- Теперь перейдите в раздел и скачайте один из них
- После скачивания архива, если он находиться в .zip формате, распакуйте его
- Установите файл ХХХ.apk как обыкновенное приложение Android
- Откройте BL
- Тапните по гаечному ключу в Блоклаунчере и зайдите в настройки
- Откройте категорию «Аддоны BL»
- Не забудьте включить поддержку аддонов, можете играть
Установка текстур-пакетов
- Установите и откройте Блоклаунчер
- Теперь можете скачать один из текстур-пакетов с
- Тапните по гаечному ключу в BlockLauncher, далее зайдите в настройки
- Зайдите в раздел «Текстур пак» и тапните «Импорт»
- Отыщите ранее скачанную текстуру и тапните по ней для того чтобы добавить
- Не забудьте активировать поддержку текстур
Установка патчей
- Установите BL
- Теперь можете загрузить один из патчей с нашего ресурса
- После скачивания патча, если он находиться в .zip архиве, распакуйте его
- Откройте BlockLauncher
- Нажмите по гаечному ключу в Блоклаунчере и далее посетите раздел настроек
- Откройте раздел «Патчи» и нажмите «Добавить»
- Найдите ранее загруженный патч и тапните по нему для того чтобы добавить
- Теперь активируйте его а также включите поддержку патчей
- Перезагрузите лаунчер, можете играть!
Установка модов (ModPE)
- Скачайте с нашего веб-ресурса (обычно они находятся в.zip архивах)
- Распакуйте ранее скачанный архив. Файлик мода может быть в формате .modpkg или .JS
- Откройте в Блоклаунчере раздел «ModPE script» и далее тапните по кнопке «Импорт»
- Отыщите файлик мода (.modpkg или .JS ), нажмите по этому файлу, для того чтобы установить мод
- Вы установили мод, хорошей игры!
Если вместе с модом идет текстура, то первым делом установите текстуру, перезапустите BL, а далее поставьте сам мод.
BlockLauncher Pro - программа при помощи которой вы сможете устанавливать на игровой клиент Minecraft Pocket Edition: моды, текстуры, аддоны, патчи и другое...
Чтобы начать пользоваться программой BlockLauncher Pro, для начала вам нужно ее скачать. Скачайте версию BlockLauncher , которая соответствует версии Minecraft PE, иначе BlockLauncher не будет корректно работать. (Если вы скачали BlockLauncher, а игру еще не установили, программа не будет работать). Далее скачайте у нас на сайте интересующий вас файл, а на сайте вы можете найти у нас: , и другое. Когда скачали интересующий вас файл, можете зайти в программу BlockLauncher Pro и установить его на игровой клиент Minecraft Pocket Edition. Все инструкции по установки модов, аддонов, текстур-паков и других дополнений вы найдете непосредственно в самих публикациях с модами, текстурами и прочими материалами.
Возможности BlockLauncher:
- Установка текстур-паков (Можно использовать 2 текстур-пака одновременно (например шейдер-пак + текстур-пак)..
- Установка шейдеров.
- Установка скинов.
- Установка патчей.
- Установка адонов BL.
- Установка ModPE Script (Моды).
- Изменение DPI.
- И другое...
BlockLauncher содержит:
- Программа содержит aFileChooser от Paul Burke.
- Программа содержит PTPatch Tool от Showbound, лицензированное под Eclipse Public License.
- Программа содержит модификация текстурпака Slickcraft от NathanX с его разрешения.
- Программа содержит части текстурпака RepetiCraft отTheevipplz and и используется с разрешения.
- Программа содержит Cybia Substrate framework от Saurik, лицензированное под GNU LGPL.
- Программа содержит libsuperuser от Chainfire.
- Программа содержит Rhino jаvascript engine от Mozilla project.
Так же вы можете воспользоваться помощью на нашем сайте, в разделе вы найдете много полезных статей, среди которых, возможно, будет ответ на ваш вопрос.
Программа обновляется вместе с выходом новых версий игры. Блоклаунчер Про версии 1.19 уже полноценно поддерживает Майнкрафт 1.5.0.14, 1.5.0.10, 1.5.0.7, 1.5 и вы можете в новой версии игры воспользоваться всеми преимуществами приложения.
Прошлые версии:
1.18.1 Pro (cкачиваний: 532)
1.17.10 Pro (cкачиваний: 245)
1.17.8 Pro (cкачиваний: 102)
1.17.4 Pro (cкачиваний: 94)
1.16.2 Pro (cкачиваний: 222)
1.16 Pro (cкачиваний: 16359)
1.15.8 Pro (cкачиваний: 4645)
1.15.5 Pro (cкачиваний: 1859)
1.15.4 Pro (cкачиваний: 2554)
1.15.2 Pro (cкачиваний: 3648)
1.15.1 Pro (cкачиваний: 2811)
1.14.4 Pro (cкачиваний: 1737)
1.14.3 Pro (cкачиваний: 1487)
1.14 Pro (cкачиваний: 2486)
1.13.3 Pro (cкачиваний: 5852)
1.13.2 Pro (cкачиваний: 1557)
1.13.1 Pro (cкачиваний: 5127) 1.13 (cкачиваний: 5127) 1.13.1 (cкачиваний: 970) 1.13 (cкачиваний: 2698) 1.12.8 (cкачиваний: 10078) 1.12.7 (cкачиваний: 3685) 1.12.5 (cкачиваний: 11971) 1.12.4 (cкачиваний: 5351) 1.11.4
Это своего рода проводник для мобильной кубической «песочницы». С помощью данного приложения вы сможете устанавливать новые патчи, текстуры, скины и многое-многое другое.
Характеристика
Это приложение может пригодиться абсолютно каждому майнкрафтеру. В настоящее время оно пользуется невероятно большой популярностью среди игроков. С помощью него можно установить практически любые дополнения.
Благодаря этой программе игроки могут навсегда забыть о бесконечном копании в файлах игры, копировании новых папок и удалении ненужных файлов. При помощи данного мода вы сможете просто переключать все необходимые расширения. Приложение самостоятельно конфигурирует клиент игры.
Эта утилита также окажется невероятно полезной для тех, кто играет на серверах. Вам нужно будет лишь выбрать новые настройки, когда вы окажетесь в другом игровом мире, где действуют новые правила. При этом переключение отнимает у вас не более нескольких секунд. Необходимо лишь добавить нужный сервер, и программа автоматически запомнит его конфигурации.
Особенности
Стоит отметить, что при установке любого дополнения необходимо убедиться в том, что оно полностью соответствует версии игры.
Если вы играете в онлайне, то обратите внимание на поддержку на серверах.Ниже вы можете скачать приложение BlockLauncher Pro абсолютно бесплатно!
