Смотреть что такое "Блоб" в других словарях. Что такое расширение файла BLOB? Не удается открыть.blob файл
A Blob object represents a file-like object of immutable, raw data; they can be read as text or binary data, or converted into a ReadableStream so its methods can be used for processing the data. Blobs can represent data that isn"t necessarily in a JavaScript-native format. The File interface is based on Blob , inheriting blob functionality and expanding it to support files on the user"s system.
Using blobs
To construct a Blob from other non-blob objects and data, use the Blob() constructor. To create a blob that contains a subset of another blob"s data, use the slice() method. To obtain a Blob object for a file on the user"s file system, see the File documentation.
The APIs accepting Blob objects are also listed in the File documentation.
Constructor
Blob() Returns a newly created Blob object which contains a concatenation of all of the data in the array passed into the constructor.Properties
Blob.size Read only The size, in bytes, of the data contained in the Blob object. Blob.type Read only A string indicating the MIME type of the data contained in the Blob . If the type is unknown, this string is empty.Methods
Blob.slice() Returns a new Blob object containing the data in the specified range of bytes of the blob on which it"s called. Blob.stream() Returns a ReadableStream that can be used to read the contents of the blob. Blob.text() Returns a promise that resolves with a USVString containing the entire contents of the blob interpreted as UTF-8 text. Blob.arrayBuffer() Returns a promise that resolves with an ArrayBuffer containing the entire contents of the blob as binary data.Examples
Creating a blob
The Blob() constructor can create blobs from other objects. For example, to construct a blob from string:
Var debug = {hello: "world"}; var blob = new Blob(, {type: "application/json"});
Creating a URL representing the contents of a typed array
The following code creates a JavaScript typed array and creates a new Blob containing the typed array"s data. It then calls createObjectURL() to convert the blob into a URL.
HTML
This example creates a typed array containing the ASCII codes for the space character through the letter Z, then converts it to an object URL. A link to open that object URL is created. Click the link to see the decoded object URL.
JavaScript
The main piece of this code for example purposes is the typedArrayToURL() method, which creates a Blob from the given typed array and returns an object URL for it. Having converted the data into an object URL, it can be used in a number of ways, including as the value of the element embeds an image into the document."> element"s src attribute (assuming the data contains an image, of course).
Let typedArrayToURL = (typedArray, mimeType) => { return URL.createObjectURL(new Blob(, {type: mimeType})) } let bytes = new Uint8Array(59); for (let i=0; i<59; i++) { bytes[i] = 32+i; } let url = typedArrayToURL(bytes, "text/plain"); let link = document.createElement("a"); link.href = url; link.innerText = "Open the array URL"; document.body.appendChild(link);
Result
Click the link in the example to see the browser decode the object URL.
Extracting data from a Blob
One way to read content from a Blob is to use a FileReader . The following code reads the content of a Blob as a typed array:
Var reader = new FileReader(); reader.addEventListener("loadend", function() { // reader.result contains the contents of blob as a typed array }); reader.readAsArrayBuffer(blob);
Another way to read content from a Blob is to use a Response. The following code reads the content of a Blob as text:
Var text = await (new Response(blob)).text();
By using other methods of FileReader , it is possible to read the contents of a Blob as a string or a data URL.
Specifications
Specification | Status | Comment |
File API The definition of "The Blob interface" in that specification. |
Working Draft | Initial definition. |
Browser compatibility
The compatibility table on this page is generated from structured data. If you"d like to contribute to the data, please check out https://github.com/mdn/browser-compat-data and send us a pull request.
Update compatibility data on GitHub
Desktop | Mobile | |||||||||||
Chrome | Edge | Firefox | Internet Explorer | Opera | Safari | Android webview | Chrome for Android | Firefox for Android | Opera for Android | Safari on iOS | Samsung Internet | |
Blob | Chrome Full support 5 | Edge Full support Yes | Firefox Full support 4 | IE Full support 10 | Opera Full support 11 | Safari Full support 5.1 | ||||||
Blob() constructor | Chrome Full support 20 | Edge ? | Firefox
Full support
13 Notes Full support 13Notes Notes | IE Full support 10 | Opera Full support 12 | Safari Full support 8 | WebView Android Full support 37 | Chrome Android Full support 25 | Firefox Android
Full support
14 Notes Full support 14Notes Notes Before Firefox 16, the second parameter, when set to null or undefined , leads to an error instead of being handled as an empty dictionary. | Opera Android ? | Safari iOS ? | Samsung Internet Android Full support 1.5 |
arrayBuffer() | Chrome Full support 76 | Edge No support No | Firefox Full support 69 | IE No support No | Opera No support No | Safari No support No | Safari iOS No support No | |||||
size | Chrome Full support 5 | Edge Full support 12 | Firefox Full support 4 | IE Full support 10 | Opera Full support 11 | Safari Full support 5.1 | WebView Android No support No | Chrome Android Full support 18 | Firefox Android No support No | Opera Android No support No | Safari iOS No support No | Samsung Internet Android Full support 1.0 |
slice() | Chrome
Full support
21 Full support
21
No support
5 - 25 Prefixed Prefixed | Edge Full support 12 | Firefox
Full support
13 Notes Full support 13Notes Notes Prior to Firefox 12, there was a bug that affected the behavior of Blob.slice() ; it did not work for start and end positions outside the range of signed 64-bit values; it has now been fixed to support unsigned 64-bit values. No support 5 - 13Prefixed Prefixed Implemented with the vendor prefix: moz | IE Full support 10 | Opera Full support 12 | Safari
Full support
5.1 Prefixed Full support 5.1Prefixed Prefixed Implemented with the vendor prefix: webkit | WebView Android Full support Yes | Chrome Android
Full support
25 Full support
25
No support
18 - 25 Prefixed Prefixed Implemented with the vendor prefix: webkit | Firefox Android Full support 14 | Opera Android Full support Yes | Safari iOS Full support Yes | Samsung Internet Android
Full support
1.5 Full support
1.5
No support
1.0 - 1.5 Prefixed Prefixed Implemented with the vendor prefix: webkit |
stream() | Chrome Full support 76 | Edge No support No | Firefox Full support 69 | IE No support No | Opera No support No | Safari No support No | WebView Android Full support 76 | Chrome Android Full support 76 | Firefox Android No support No | Opera Android No support No | Safari iOS No support No | Samsung Internet Android No support No |
Обычно этот термин применяется только по отношению к модулям, загружаемым в ядро свободной или открытой операционной системы; термин редко применяется по отношению к коду, выполняющемуся не в режиме ядра, например, код BIOS , микропрограммный код устройств , программы, выполняющиеся в пользовательском режиме.
Операционные системы, не приемлющие блобы:
Примечания
См. также
Ссылки
Wikimedia Foundation . 2010 .
Смотреть что такое "Блоб" в других словарях:
Сущ., кол во синонимов: 3 аттракцион (7) катапульта (3) подушка (28) С … Словарь синонимов
блоб - Примитив криптографического протокола, который содержит только битовое обязательство (строку из символов 0 или 1), соответствующее определенному логическому выражению. [Л.М. Невдяев. Телекоммуникационные технологии. Англо русский толковый словарь … Справочник технического переводчика
- (англ. Globster), также иногда называемый блоб (англ. blob), неопознанная органическая масса, вымываемая на берега океанов или других водоёмов. Каждый раз туши глобстеров находят недалеко от моря (чаще всего после бури, поэтому, очевидно,… … Википедия
Связать? Камень сновидений … Википедия
- (англ. proprietary software; от proprietary частное, патентованное, в составе собственности и software программное обеспечение) программное обеспечение, являющееся частной собственностью авторов или… … Википедия
Камень сновидений The Dreamstone (англ.) Жанры комедия, семейный Мультсериал … Википедия
Проприетарное, частное или собственническое программное обеспечение (англ. proprietary software) программное обеспечение, являющееся частной собственностью авторов или правообладателей и не удовлетворяющее критериям свободы ПО (речь именно о… … Википедия
Популярность EVE Online далеко не в последнюю очередь обеспечена кадрами с космическими сражениями огромных масштабов. Тем, кому интересно такое времяпровождение обязательно нужно вступить в корпорацию, специализирующуюся на PVP блобах в EVE Online. Приготовьтесь к тому, что вам придётся тратить большое количество времени, а также во всём слушаться вашего командира. PVP блоб в EVE Online - ответственное дело и если вы несколько раз не явитесь на КТА ("call to arms" - "призыв к оружию", "всеобщий сбор"), то вы рискуете попасть в немилость, получить штрафные санкции или даже вылететь из корпорации.
Зарегистрируйтесь в EVE Online , чтобы иметь возможность окунуться в приключения глобальных масштабов. Бесплатный триал позволит вам сделать это!
PVP блоб в EVE Online - что нужно знать?
Самое главное правило - беспрекословно подчиняться командиру и выполнять все его указания. Он может приказать вам пересесть на необходимый для определенных целей корабль, сказать, какие навыки вы обязаны учить. Всё это необходимо потому, что PVP блоб в EVE Online - монолитная структура, нуждающаяся в тщательном подборе участников и кораблей. Для достижения хороших результатов необходима полноценная координация, поэтому без дополнительной гарнитуры и программ голосовой связи вам не обойтись. Также, PVP блоб в мире EVE Online не предусматривает никаких самостоятельных действий - активация гиперворот или стрельба без приказа - одни из самых серьёзных нарушений в этом виде деятельности. Масштабные боевые действия проводятся лишь в глубоких "нулях" - только там есть пространство и возможности для того, чтобы развернуть настоящие серьёзные военные действия.
Что учить для участия в PVP блобах?
Необходимые для изучения навыки напрямую зависят от военной доктрины и целей вашей корпорации и альянса. Как минимум - вы должны уметь отлично управляться с линкорами или специализированными Т2 кораблями и использовать все возможные для вашего корабля Т2 модули.
На чем летать?
На том, что необходимо на данный момент вашему командиру и корпорации - спросите в первую очередь у него. Обычно, у всех альянсов и корпораций есть свои готовые доктрины и стратегии, списки рекомендуемых кораблей и фитов для них.
Эти файлы BLOB можно просматривать с помощью один существующего (-их) прикладных (-ого) программных (-ого) средств (-а), как правило, Steam , разработанного Valve . Оно связано с один основным (-и) типом (-ами) файла (-ов), но часто встречается в формате Valve Steam Archive . Большинство файлов BLOB относится к Settings Files .
Файлы с расширением BLOB были идентифицированы на настольных компьютерах (и некоторых мобильных устройствах). Они полностью или частично поддерживаются Windows, Mac и Linux. Рейтинг популярности расширения файла BLOB составляет «Низкий», что означает, что эти файлы, как правило, не встречаются в большинстве файловых хранилищ пользователя.
Для получения дополнительной информации о файлах BLOB и связанных с ними прикладных программных средствах, см. информацию ниже. Кроме того, далее также представлено основное руководство по устранению неполадок, которое позволит вам решить проблемы, возникающие во время открытия файлов BLOB.
Популярность типов файлов
Ранг Файла
Активность
Этот тип файлов по-прежнему сохранил актуальность и активно используется разработчиками и прикладными программными средствами. Хотя оригинальное программное обеспечение этого типа файлов может отодвигаться на второй план более новой версией (например. Excel 97 против Office 365), этот тип файлов по-прежнему активно поддерживается текущей версией программного обеспечения. Этот процесс взаимодействия со старой операционной системой или устаревшей версией программного обеспечения также известен как «обратная совместимость ».
Статус файла
Страница Последнее обновление
Типы файлов BLOB
Ассоциация основного файла BLOB
BLOB
Расширение файла BLOB является файл данных, который ссылается паровой клапан корпорации. Паровой Valve Corporation является интерактивной программой распространения программного обеспечения, которое используется для регистрации информации хранит пользователь для клиента Steam. Информация о регистрации пользователя хранится в файле с именем ClientRegistry.blob. Файлы BLOB данных обычно сохраняются с расширением БСП.
Попробуйте универсальное средство для просмотра файлов
В дополнение к продуктам, перечисленным выше, мы предлагаем вам попробовать универсальное средство для просмотра файлов типа FileViewPro. Данное средство может открывать более 200 различных типов файлов, предоставляя функции редактирования для большинства из них.
Лицензия | | Условия |
Устранение неполадок при открытии файлов BLOB
Общие проблемы с открытием файлов BLOB
Steam не установлен
Дважды щелкнув по файлу BLOB вы можете увидеть системное диалоговое окно, в котором сообщается «Не удается открыть этот тип файла» . В этом случае обычно это связано с тем, что на вашем компьютере не установлено Steam для %%os%% . Так как ваша операционная система не знает, что делать с этим файлом, вы не сможете открыть его дважды щелкнув на него.
Совет: Если вам извстна другая программа, которая может открыть файл BLOB, вы можете попробовать открыть данный файл, выбрав это приложение из списка возможных программ.
Установлена неправильная версия Steam
В некоторых случаях у вас может быть более новая (или более старая) версия файла Valve Steam Archive, не поддерживаемая установленной версией приложения . При отсутствии правильной версии ПО Steam (или любой из других программ, перечисленных выше), может потребоваться загрузить другую версию ПО или одного из других прикладных программных средств, перечисленных выше. Такая проблема чаще всего возникает при работе в более старой версии прикладного программного средства с файлом, созданным в более новой версии , который старая версия не может распознать.
Совет: Иногда вы можете получить общее представление о версии файла BLOB, щелкнув правой кнопкой мыши на файл, а затем выбрав «Свойства» (Windows) или «Получить информацию» (Mac OSX).
Резюме: В любом случае, большинство проблем, возникающих во время открытия файлов BLOB, связаны с отсутствием на вашем компьютере установленного правильного прикладного программного средства.
Установить необязательные продукты - FileViewPro (Solvusoft) | Лицензия | Политика защиты личных сведений | Условия |
Другие причины проблем с открытием файлов BLOB
Даже если на вашем компьютере уже установлено Steam или другое программное обеспечение, связанное с BLOB, вы все равно можете столкнуться с проблемами во время открытия файлов Valve Steam Archive. Если проблемы открытия файлов BLOB до сих пор не устранены, возможно, причина кроется в других проблемах, не позволяющих открыть эти файлы . Такие проблемы включают (представлены в порядке от наиболее до наименее распространенных):
- Неверные ссылки на файлы BLOB в реестре Windows («телефонная книга» операционной системы Windows)
- Случайное удаление описания файла BLOB в реестре Windows
- Неполная или неправильная установка прикладного программного средства, связанного с форматом BLOB
- Повреждение файла BLOB (проблемы с самим файлом Valve Steam Archive)
- Заражение BLOB вредоносным ПО
- Повреждены или устарели драйверы устройств оборудования, связанного с файлом BLOB
- Отсутствие на компьютере достаточных системных ресурсов для открытия формата Valve Steam Archive
Опрос: Какой тип вычислительного устройства, наиболее часто используют для открытия файлов?
Лучшие веб-браузеры
Chrome | (58.80%) | |
Firefox | (11.05%) | |
Internet Explorer | (9.04%) | |
Edge | (8.46%) | |
Safari | (3.87%) |
Событие дня
Потеря, которое происходит в форматы с потерями файлов, когда они будут изменены и сохранены в виде новых файлов, таких как JPEGS и многие другие, является постоянным. Это означает, что когда-то размер изображения уменьшается, размер оригинала никогда не может быть восстановлен.
Как исправить проблемы с открытием файлов BLOB
При наличии на компьютере установленной антивирусной программы можносканировать все файлы на компьютере, а также каждый файл в отдельности . Можно выполнить сканирование любого файла, щелкнув правой кнопкой мыши на файл и выбрав соответствующую опцию для выполнения проверки файла на наличие вирусов.
Например, на данном рисунке выделен файл my-file.blob , далее необходимо щелкнуть правой кнопкой мыши по этому файлу, и в меню файла выбрать опцию «сканировать с помощью AVG» . При выборе данного параметра откроется AVG Antivirus, который выполнит проверку данного файла на наличие вирусов.
Иногда ошибка может возникнуть в результате неверной установки программного обеспечения , что может быть связано с проблемой, возникшей в процессе установки. Это может помешать вашей операционной системе связать ваш файл BLOB с правильным прикладным программным средством , оказывая влияние на так называемые «ассоциации расширений файлов» .
Иногда простая переустановка Steam может решить вашу проблему, правильно связав BLOB с Steam. В других случаях проблемы с файловыми ассоциациями могут возникнуть в результате плохого программирования программного обеспечения разработчиком, и вам может потребоваться связаться с разработчиком для получения дополнительной помощи.
Совет: Попробуйте обновить Steam до последней версии, чтобы убедиться, что установлены последние исправления и обновления.
Это может показаться слишком очевидным, но зачастую непосредственно сам файл BLOB может являться причиной проблемы . Если вы получили файл через вложение электронной почты или загрузили его с веб-сайта, и процесс загрузки был прерван (например, отключение питания или по другой причине), файл может повредиться . Если возможно, попробуйте получить новую копию файла BLOB и попытайтесь открыть его снова.
Осторожно: Поврежденный файл может повлечь за собой возникновение сопутствующего ущерба предыдущей или уже существующей вредоносной программы на вашем ПК, поэтому очень важно, чтобы на вашем компьютере постоянно работал обновленный антивирус.
Если ваш файл BLOB связан с аппаратным обеспечением на вашем компьютере , чтобы открыть файл вам может потребоваться обновить драйверы устройств , связанных с этим оборудованием.
Эта проблема обычно связана с типами мультимедийных файлов , которые зависят от успешного открытия аппаратного обеспечения внутри компьютера, например, звуковой карты или видеокарты . Например, если вы пытаетесь открыть аудиофайл, но не можете его открыть, вам может потребоваться обновить драйверы звуковой карты .
Совет: Если при попытке открыть файл BLOB вы получаете сообщение об ошибке, связанной с.SYS file , проблема, вероятно, может быть связана с поврежденными или устаревшими драйверами устройств , которые необходимо обновить. Данный процесс можно облегчить посредством использования программного обеспечения для обновления драйверов, такого как DriverDoc .
Если шаги не решили проблему , и у вас все еще возникают проблемы с открытием файлов BLOB, это может быть связано с отсутствием доступных системных ресурсов . Для некоторых версий файлов BLOB могут потребоваться значительный объем ресурсов (например, память/ОЗУ, вычислительная мощность) для надлежащего открытия на вашем компьютере. Такая проблема встречается достаточно часто, если вы используете достаточно старое компьютерное аппаратное обеспечение и одновременно гораздо более новую операционную систему.
Такая проблема может возникнуть, когда компьютеру трудно справиться с заданием, так как операционная система (и другие службы, работающие в фоновом режиме) могут потреблять слишком много ресурсов для открытия файла BLOB . Попробуйте закрыть все приложения на вашем ПК, прежде чем открывать Valve Steam Archive. Освободив все доступные ресурсы на вашем компьютере вы обеспечите налучшие условия для попытки открыть файл BLOB.
Если вы выполнили все описанные выше шаги , а ваш файл BLOB по-прежнему не открывается, может потребоваться выполнить обновление оборудования . В большинстве случаев, даже при использовании старых версий оборудования, вычислительная мощность может по-прежнему быть более чем достаточной для большинства пользовательских приложений (если вы не выполняете много ресурсоемкой работы процессора, такой как 3D-рендеринг, финансовое/научное моделирование или интенсивная мультимедийная работа). Таким образом, вполне вероятно, что вашему компьютеру не хватает необходимого объема памяти (чаще называемой «ОЗУ», или оперативной памятью) для выполнения задачи открытия файла.
Попробуйте обновить память , чтобы узнать, поможет ли это открыть файл BLOB. На сегодняшний день обновления памяти являются вполне доступными и очень простыми для установки даже для обычного пользователя компьютера. В качестве бонуса вы, вероятно, увидите хороший прирост производительности при выполнении вашим компьютером других задач.
